Print at Aug 24, 2026, 9:09:24 PM
Posted by Clamarc at Mar 16, 2021, 7:44:45 PM
Imported furniture
I imported a furniture, door handle, in .dae format and checked the option to add to the catalog. I was wondering where this furniture was saved, because when I open the furniture catalog at C:\ Users\xxxxx\AppData\Roaming\eTeks\Sweet Home 3D\ furniture, the furniture is not in the file forniture.sh3f nor in the file contributions.sh3f! ... where was the furniture that was imported saved?
Thanks
Clamarc
Posted by Puybaret at Mar 17, 2021, 3:02:44 PM
Re: Imported furniture
They are stored in .pref files.
Posted by Clamarc at Mar 22, 2021, 7:47:15 AM
hi, Puybaret
But aren't they converted to .obj if I want to make a change to the file?
thanks
Clamarc
Posted by Puybaret at Mar 22, 2021, 11:45:01 AM
Imported 3D models are not always converted to OBJ format. The content of ZIP files are not modified for example. But you shouldn't rely on this because it could change one day, the reason why files are suffixed by .pref to avoid users changing them.
If you want to edit a 3D model at OBJ format, you should rather import it then export it with the 3D view > Export to OBJ format menu item.
Posted by Clamarc at Apr 17, 2021, 3:11:55 AM
Thanks Puybaret!... it helped me a lot!
Thanks and congratulations for the work!
Clamarc
