Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Levels Elevation Change |
| Print at Sep 10, 2026, 12:36:59 AM | |
| Posted by snmavronis at Mar 9, 2021, 1:34:01 AM |
Levels Elevation Change In the Modify Level dialog box if I change the 3 level's elevations so that the basement is 0' elevation and adjusted the other 2 levels relative to that, do each item's elevations within each level adjust accordingly so everything looks the same as before? I want to raise the entire house so I can make the proper landscape outside that slopes away from the house, because ground level is several feet below the main level elevation. ![]() ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by Puybaret at Mar 9, 2021, 3:41:11 PM |
Re: Levels Elevation Change If you just want to raise the whole design, you should add the same value to the elevation of each level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by snmavronis at Mar 9, 2021, 4:07:41 PM |
Re: Levels Elevation Change For example then I should just add 7’9 7/8” to each level. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by Puybaret at Mar 9, 2021, 4:52:39 PM |
Re: Levels Elevation Change Yes, just add 7’9 7/8” in your case. Anyway, keep in mind that Sweet Home 3D proposes 2 guardrails when you make an error: undo and reloading the current home without saving it ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by snmavronis at Mar 9, 2021, 6:54:18 PM |
Re: Levels Elevation Change Yes the undo feature is quite generous. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Sep 10, 2026, 12:36:59 AM |
