Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How can i remove text from my house? |
| Print at Sep 21, 2026, 8:30:22 AM | View all posts in this thread on one page |
| Posted by noise694 at Mar 1, 2021, 4:35:43 PM |
How can i remove text from my house? Hi, im new at sweet home 3d, i added a text to my house and now i can´t remove it. Can someone help pls? |
| Posted by Puybaret at Mar 2, 2021, 10:47:24 PM |
Re: How can i remove text from my house? Did you try to click on it to select it and choose Edit > Delete menu item? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Rickster55 at May 17, 2024, 1:42:29 AM |
Re: How can i remove text from my house? I`m having the same problem. I tried clicking on the text, but nothing happens. It`s like there`s no object there. I even tried `Select All` which selects all the object, but no text. |
| Posted by Puybaret at May 17, 2024, 10:23:02 AM |
Re: How can i remove text from my house? Maybe it’s the name of a piece of furniture in which case you should unselect Display name in plan check box in its modification dialog box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by MarioSambol at Jan 17, 2025, 8:17:05 PM |
Re: How can i remove text from my house? It sounds stupid if the text is in a locked level, if you use them |
| Posted by MarioSambol at Jan 21, 2025, 1:37:28 AM |
Re: How can i remove text from my house? Text is always on the base plan level. If the base plan is locked, the text cannot be selected. Unlock the base plan and then it is possible to select and delete the text. If you opened the furniture properties by double-clicking on the object, deselect the enabled option to show the name of the object. |
Current timezone is GMT Sep 21, 2026, 8:30:22 AM |
