Print at Sep 24, 2026, 12:24:04 AM
Posted by HABITALIA at Feb 25, 2021, 8:01:10 AM
THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
HELLO:
THE OTHER DAY I CLOSED THE APPLICATION AND WHEN I OPENED IT AGAIN, IT HAS REPLACED ALL THE OBJECTS WITH FRAMES WITH AN "X" AND IN THE 3D VIEW EVERYTHING IS LIKE GEOMETRIC FIGURES. ANYONE KNOWS THE REASON? THANKS A LOT
Posted by hansmex at Feb 25, 2021, 10:13:58 AM
Re: THE IMAGES ARE NOT UPLOADED (DOORS, FURNITURE, ...)
Did you move the design to another directory? Update your computer? Changed the directory structure?
Aside... which OS do you use, which version of SH3D?
Posted by HABITALIA at Feb 25, 2021, 11:22:01 AM
Good morning:
I did nothing. I even open another file that I use from the same work and it comes out perfectly. The system is windows 10. It only happens to me in this file. Thanks
Posted by Puybaret at Feb 25, 2021, 11:49:57 AM
Your file might be damaged. Sent it to me, I'll try to understand the problem and fix it if possible.
