Print at Sep 10, 2026, 2:33:13 AM
Posted by Andrey.V. at Feb 17, 2021, 5:50:17 PM
confused   How can I accurately snap dimension lines to the edges of the walls?
Posted by Denis1874 at Feb 17, 2021, 11:40:55 PM
Re: How can I accurately snap dimension lines to the edges of the walls?
Hello,
normally when you draw the dimension line, you have a color change when you are perfectly aligned. If you change afterwards the wall length, you need to delete and create again the dimension line if you want to use this again.
MacMini 3GHz Intel Core i5 6 cores 64Go macOS Big Sur 12.2.1
Posted by Puybaret at Feb 18, 2021, 9:50:57 AM
There's also a faster solution: when the dimension lines creation tool is active, just place the mouse pointer along a wall side and double click to create the matching dimension line. See also this video.
