Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Shop Equipment and Tools |
| Print at Sep 21, 2026, 5:02:12 AM | |
| Posted by meengrn at Feb 7, 2021, 10:40:03 PM |
Shop Equipment and Tools I've searched this forum and all the libraries I can find for shop equipment with no luck. Table saws, drill presses, tool cabinets, peg board, bench grinders and similar. Any guidance appreciated. |
| Posted by hansmex at Feb 12, 2021, 10:04:53 AM |
Re: Shop Equipment and Tools On the 3D models page, the Trimble Sketchup Warehouse is listed. Obviously you didn't look there.... table saw drill press tool cabinet peg board bench grinder Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by jarroyo at Apr 30, 2022, 8:15:29 PM |
Re: Shop Equipment and Tools Is there a way to convert the SKP file formats to a compatible format (obj, dae, kmz, or 3ds) to use with Sweet Home 3d? |
| Posted by rustypheonix at Sep 1, 2022, 8:04:13 PM |
Re: Shop Equipment and Tools I have found that I do not need to convert when I download from the Trimble warehouse. There is an option at the bottom of the pull down menu in that site when you download the item to down load in Collada format. Sweethome can import those files just fine. Now if you find a SKP file somewhere else, there are online converters that I found, but not tried, that can convert to OBJ format. |
| Posted by Puybaret at Sep 2, 2022, 12:31:59 AM |
Re: Shop Equipment and Tools Yes, as explained in this page ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 21, 2026, 5:02:12 AM |
