Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Compiling Textures Library Editor |
| Print at Oct 9, 2026, 10:45:53 AM | |
| Posted by treehousenorris2 at Feb 5, 2021, 8:58:20 PM |
Compiling Textures Library Editor Hello, I was able to build the Furniture Library Editor using JDK 8 for the SweetHome project jre and the Furniture Editor project jre and the Ant runtime configuration jre, and xml target=1.5. Now when trying to build the jarExecutable of the Textures Library Editor (with the above java versions) I'm getting a java.awt.desktop package does not exist error, and I see that the Textures Editor README says to use JDK 5 or 6 to build. The Ant runtime configuration jre says "JRE version less than 1.8 is not supported", and though I changed the Texture Editor and SweetHome project jres from JDK 8 to 5, I am still getting the same error, as seen below. Some more information on the required desktop version or the SweetHome project version would be helpful. Thank you! ![]() |
| Posted by Puybaret at Feb 5, 2021, 10:23:59 PM |
Re: Compiling Textures Library Editor In build.xml of Textures Library Editor, you should add the line: <pathelement location="../SweetHome3D/libtest/javaAwtDesktop.jar"/><pathelement location="../SweetHome3D/libtest/jnlp.jar"/>or build the project with Sweet Home 3D 6.1 source code as suggested in README.TXT. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by treehousenorris2 at Feb 15, 2021, 6:28:34 PM |
Re: Compiling Textures Library Editor Awesome, adding the path element worked. Thank you! |
Current timezone is GMT Oct 9, 2026, 10:45:53 AM |
