Print at Oct 1, 2026, 10:15:04 PM
Posted by jeromego at Jan 27, 2021, 6:25:29 PM
Undesired sun light over the walls in aerial view...
I have a house floor plan desgined in SH3D, and I would like to generate an aerial view (so a view from top), with the sun light (all interior lights off).
But when I render, the sun light is going over the walls, so I have lights and shadows just like if my floor has no ceiling...
I don't want the ceiling to appear on the render, but I would the sun light to behave as if there is a ceiling...
Any idea how I can do that ? Or what I'm doing wrong.
Thanks
Posted by Puybaret at Jan 27, 2021, 7:29:12 PM
Re: Undesired sun light over the walls in aerial view...
It's not possible. Lighting works like in real life. Opening the cover of a box will let light enter in it.
Posted by DATAstrm at Feb 6, 2022, 7:33:08 PM
It would be great if the root/second floor are invisible in aerial view but still somehow cast shadows based on light sources.
The goal would be to get an overhead view of what a floor would look like if you could somehow see through the celings (rather than the ceilings not being there). Like superman when he looks through a wall, it doesn't let more light into the room by deleting the wall.
Posted by Puybaret at Feb 6, 2022, 8:10:57 PM
Sorry but you shouldn’t hope for such a feature because I don’t think any rendering engines can do that, and I’m not Superman wink
Posted by DATAstrm at Feb 6, 2022, 9:55:50 PM
You seem to be superman - having developed this great program.
It seems like this feature is possible with some renderers (see https://blender.stackexchange.com/questions/1...e-invisible-in-the-render) -- but if it's not possible in this one, that's fine. Thanks for investigating. It would be a really great feature though, if possible.
I think it would involve using a transparent effect if the ray is from the object to the camera, but not otherwise.
Thanks for the responses. I hope my persistence doesn't come across as off putting.
Posted by sjb007 at Feb 7, 2022, 5:13:25 PM
@DATAstrm I used some clever trickery in Blender to create a room where when the viewpoint is in the room all the walls, ceiling are visible. When outside the room the walls, ceiling and objects between you and room automatically disappear and reappear, but they still cast shadows. I used the same "Is Camera Ray" + Transparent into a mixer that you point to, but also a Geometry:Incoming + some other math nodes to achieve the magic disappearing act.
I think SH3D is wonderful, and very good for figuring out your space. But if you want ArchViz grade imagery, or clever tricks like you describe, I just don't think Emmanuel has the bandwidth to implement every feature people dream up. You need to either move to (very expensive) commercial products, or you have to learn how to beat blender into submission. I chose option 2. smile
