Print at Aug 25, 2026, 11:55:37 PM View all posts in this thread on one page
Posted by HammerCam at Jan 10, 2021, 8:34:26 PM
Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open
Just purchased from the Apple Mac App store and it tries to open, but doesn't actually open - just crashes.
Trying to see what I need to do to install but everything references an older version of Sweet Home 3D and not v6.4.7.
Java is installed and everything I download directly from your website also crashes and doesn't open.
Running macOS Big Sur v11.1 on a MacBook Pro (15-inch, 2019)
Looking for direction, was referred to this product from multiple people, excited to give it a whirl.
Posted by Puybaret at Jan 10, 2021, 10:24:26 PM
Re: Just purchased v6.4.7 from Mac App Store and Big Sur 11.1 - Crashes won't open
Could you try to run it from a Terminal window?
Open Terminal application, drag and drop Sweet Home 3D icon on Terminal window, add /Contents/MacOS/SweetHome3D after Sweet\ Home\ 3D.app to obtain something like:
/Applications/Sweet\ Home\ 3D.app/Contents/MacOS/SweetHome3D
Then, press <enter> and copy paste here the text that will be displayed. This could help fix your issue.
Posted by tdavisson at Jan 28, 2021, 7:38:10 PM
Running to this exact same issue. When I followed your instructions above to run it through terminal I was successful in getting the program to launch. Any thoughts?
Posted by Puybaret at Jan 29, 2021, 3:07:34 PM
Could you check if you have this issue with the free version 6.4.2 and in the beta version 6.5?
Posted by Joan20 at Feb 11, 2021, 5:07:42 AM
Following this. I am having this issue with the beta 6.5
Posted by Puybaret at Feb 11, 2021, 8:48:50 AM
Joan20, your last message made me think you was a Ubuntu user. Did you change your computer? Does it run from a Terminal window?
Posted by silaspeter at Feb 18, 2021, 6:51:09 PM
Has this problem been solved.
I wil not upgrade to Big Sur if it has not
