Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Need help with door model |
| Print at Aug 20, 2026, 2:57:51 PM | |
| Posted by Shralen at Jan 7, 2021, 10:03:02 PM |
Need help with door model I've found this model that is close to what I want: ![]() In case the image broke: https://sta.sh/0afslj1lz3y But as you see, it doesn't render well on the wall + some parts that should be hidden are not. What I want is a model that looks like this: In case the image broke: https://tos.trekcore.com/gallery/albums/set-t.../set-tour-corridor-08.jpg https://www.youtube.com/watch?v=FVtB2Lrd1vg (How it works, open around 0:28.) Can any of you make me a model of this? It doesn’t have to open. ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Puybaret at Jan 8, 2021, 6:04:55 PM |
Re: Need help with door model Why not simply importing a double door model or even elevator doors ? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Shralen at Jan 8, 2021, 7:30:13 PM |
Re: Need help with door model So I tried some of the double door, I had to make some part invisible to look like wanted, but it worked. ![]() In case the image broke: https://sta.sh/0dw6p46h3sm Thank you. ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Shralen at Jan 10, 2021, 8:05:07 PM |
Re: Need help with door model So I tried a few more things with the door. I've been trying to make the door border pop out of the wall. As the door on the left, but no matter what I do the door is always inside the wall. In case the image broke: https://sta.sh/01jxteopiak6 ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
| Posted by Puybaret at Jan 10, 2021, 10:38:29 PM |
Re: Need help with door model Enlarge the depth of the door and move it with magnetism disabled. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Shralen at Jan 11, 2021, 8:02:31 PM |
Re: Need help with door model Worked, thanx you. In case the image broke: https://sta.sh/0u6emm78mol ---------------------------------------- I'm more comfortable writing in English, but I can also write in French. ,___, (OvO) Hoot /)_) " " |
Current timezone is GMT Aug 20, 2026, 2:57:51 PM |
