Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor shadow on the ceiling |
| Print at Sep 24, 2026, 3:47:24 AM | |
| Posted by paolocesari at Jan 6, 2021, 8:05:57 AM |
Floor shadow on the ceiling Hi, after creating a model with some levels, on 3D view I've found the floor shadow on the ceiling. Here the some examples: ![]() ![]() And my levels: How can I solve the problem? Thanks to all! [Note from moderator: fixed links to images, be sure to use "Direct Link" option] |
| Posted by Puybaret at Jan 6, 2021, 5:38:21 PM |
Re: Floor shadow on the ceiling This must be the ceiling of some rooms. The height of a level is used to compute the elevation of ceilings and you should enter the height of the level, not the altitude of the ceilings. So I guess the last column of your level modification dialog box should rather display 320. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by paolocesari at Jan 7, 2021, 6:01:20 AM |
Re: Floor shadow on the ceiling I'm really stupid, as you say the height of the rooms should be set at 320 cm. Problem solved, thank you very much! |
Current timezone is GMT Sep 24, 2026, 3:47:24 AM |
