Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: command line and/or .ini files for Java3D13? |
| Print at Aug 21, 2026, 8:58:53 AM | View all posts in this thread on one page |
| Posted by jeffk at Sep 12, 2009, 12:13:43 AM |
command line and/or .ini files for Java3D13? On both our computers, on all of Ubuntu 9.04, Windows XP SP3, and Gentoo Linux, SweetHome3D has the full measure of the 3D problem: http://www.sweethome3d.eu/faq.jsp#errorIn3DRenderingSystem We don't use Java or Java Web Start in our browsers. Can you post the command line invocation and/or .ini files that would start SweetHome3D-2.0 in the Java3D1.3 mode on Windows and Linux? The DirectX .ini is similar to I'm looking for: http://www.sweethome3d.eu/SweetHome3D.l4j.ini, but we use OpenGL, not DirectX. # Place this file in the same directory as SweetHome3D.exe file to always run Sweet Home 3D with DirectX Thanks, Jeff |
| Posted by Puybaret at Sep 12, 2009, 1:37:17 PM |
Re: command line and/or .ini files for Java3D13? Running Sweet Home 3D with Java 3D 1.3 requires you to download an older version of Java 3D, and this can't be changed with a .ini file. Here's what you can try:
![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jeffk at Sep 13, 2009, 3:16:20 AM |
Re: command line and/or .ini files for Java3D13? Thanks, the lib/dll downgrade to java3d-1.3.2 does appear to work better. I can access the properties and print preview as well as I could with the DirectX method. As a user data point of what doesn't work out of the box, but will with java3d downgrade: this is on a laptop with a Mobile Intel 965 Express chipset with integrated graphics. The driver is version 6.14.10.4906. |
Current timezone is GMT Aug 21, 2026, 8:58:53 AM |
