Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: HOW TO CREATE LIGHTS??? |
| Print at Sep 24, 2026, 5:23:07 PM | View all posts in this thread on one page |
| Posted by baldatito at Dec 16, 2020, 6:56:11 PM |
HOW TO CREATE LIGHTS??? Hi. I know that this topic is been touched before, but I need more help. I follow all the steps to create a light source, and does not work at all!!! I edit the PluginFurnitureCatalog.properties and nothing... I use .dae files but I have also tried with .obj after exporting from SH3D. I do not get it as lights... Also, how do I do for the object to go to the ceiling straight away.. Is it also possible to get them dimable like the ones included in SH3D?? Dont want an object with light source, I want a proper light... I use MAC... Please help....I am desperate... |
| Posted by Puybaret at Dec 16, 2020, 9:47:49 PM |
Re: HOW TO CREATE LIGHTS??? Could you share the content of your PluginFurnitureCatalog.properties file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by baldatito at Dec 17, 2020, 1:19:59 PM |
Re: HOW TO CREATE LIGHTS??? name#1=DOWNLIGHT 1 tags#1=DOWNLIGHT 1 category#1=Unknown icon#1=/DOWNLIGHT 1.png model#1=/DOWNLIGHT 1/model.dae multiPartModel#1=true width#1=10.99997 depth#1=10.99997 height#1=1.2 movable#1=true doorOrWindow#1=false modelSize#1=102850 creator#1=TITO lightSourceX#1=5.5 lightSourceY#1=5.5 lightSourceZ#1=0 lightSourceColor#1=#ffffff lightSourceDiameter#1=10 |
| Posted by Puybaret at May 10, 2021, 12:05:39 PM |
Re: HOW TO CREATE LIGHTS??? Does the object "DOWNLIGHT 1" appear in the furniture catalog once you installed the SH3F file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by baldatito at May 28, 2021, 5:44:23 PM |
Re: HOW TO CREATE LIGHTS??? Yes, when I import the item then I drag it into the room but nothing. No light... |
| Posted by Puybaret at May 28, 2021, 8:58:21 PM |
Re: HOW TO CREATE LIGHTS??? Just to be sure, did you understand that lights have some visible effect only at the two best quality levels of the photo creation tool? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by baldatito at May 31, 2021, 9:13:14 PM |
Re: HOW TO CREATE LIGHTS??? Well I did not know. Anyhow, I always use the two best quality levels of photo rendering. Still nothing. If it worked, I should be able to change the brightness of the light, and that does not happens... kind of lost... Again, thanks a lot. |
Current timezone is GMT Sep 24, 2026, 5:23:07 PM |
