Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Need help |
| Print at Sep 24, 2026, 9:20:42 PM | |
| Posted by daveywavey at Dec 5, 2020, 12:17:40 PM |
Need help Hello, everyone, I would like to make a round room cutout of 180 cm on the first floor, so that one can see a sculpture in the basement. Can someone please help me in a friendly manner? Thanks! ---------------------------------------- What is Synthetic Voice |
| Posted by hansmex at Dec 5, 2020, 3:09:44 PM |
Re: Need help STEP BY STEP EXAMPLE - Draw a room of 8x8 meters - In the middle of the room draw a wall 180 cms long - Modify walls > Arc Extent > 180 degrees - This gives a semi-circular wall - Draw a second wall from exactly the same X,Y coordinates - Modify walls > Arc Extent > 180 degrees - This gives a prefect circle in the middle of the room - Draw a wall from one corner to the diagonally opposing corner, this bisects room and the circle - Give walls a thickness of 0.1 cm - Insert two rooms - You now have two rooms with a semi-circular opening - Delete interior walls used for construction - You are left with a perfect hole in the floor (and a narrow diagonal slit). example file H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 24, 2026, 9:20:42 PM |
