Print at Sep 20, 2026, 5:42:09 PM View all posts in this thread on one page
Posted by Makiese at Nov 10, 2020, 11:32:44 PM
Render - Texture Problem
Hello,
i currently have massive problems with rendering textures in a project. As soon as I try to render a project with a render level 3 or 4 (BEST) the texture of the ground disappears. It almost looks like an empty white texture layer is always inserted automatically. At level 1 to 2 everything is ok.
See more in the pictures. What am I doing wrong?
Render Step level 1 or 2 - OK
https://sta.sh/03l8twvgwyx
Render Step level 3 or 4 - FAIL
https://sta.sh/02e3w4ii7ikt
Render Settings - FAIL
https://sta.sh/01vg90jkhrjo
I use:
Sweet Home 3D Version 6.4
Java Version 1.8.0_202 (64Bit)
YafarayRendering-1.3.2
and pretty much everything about plugins that is possible at all.
The effect also occurs with all other render engines available for Sweet Home 3D.
Thanks for help in advance!
Posted by Puybaret at Nov 10, 2020, 11:43:54 PM
Re: Render - Texture Problem
This could be the ceiling of a level below. Ceilings are visible from top and bottom at the two best quality levels.
Posted by Makiese at Nov 10, 2020, 11:59:56 PM
Dawm! You are right!
I have created several height levels for the floor. In one of them the ceiling display was active. I have already spent 3.5 hours with the search. Thank you so much!
