Print at Aug 26, 2026, 4:14:56 AM
Posted by mmrak at Oct 17, 2020, 9:40:57 AM
Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
Since the latest Update of Big Sur Beta Sweet Home 3D crashes on both my MacBook and on my iMac. I have tested both versions, 6.4.2 (from SourceForge) and 6.4.3 (just purchased from the App Store), both crash at startup, please see attached crashlog.
I was able to use Sweet Home 3D without issues since Beta 4 of Big Sur.
Any hints or workarounds? Uninstalling and reinstalling did not help.
Kind regards
Michael
Posted by Puybaret at Oct 17, 2020, 10:58:03 AM
Re: Version 6.4.2 and 6.4.3 crashes on latest MacOS 11 Big Sur Beta
Please report this issue to Apple and check bug ticket #976 for workarounds.
Posted by mmrak at Oct 18, 2020, 9:51:01 AM
Hi Emmanuel,
it did so and sent the bug Reports to Apple. But as I have written above its not the 3D mode that is not working, its the program that crashes at startup. So it might be a different reason.
Posted by 61Xray at Oct 25, 2020, 5:31:59 PM
Hi Emmanuel,
The crashlog gives the following error:
Exception Type: EXC_BAD_INSTRUCTION (SIGABRT)
Exception Codes: 0x0000000000000001, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
-[NSOpenGLContext setView:] must be called from the main thread.
Don't know if this helps.
Regards,
Michael
Posted by mmrak at Oct 28, 2020, 7:40:42 PM
Hi, is there any progress at this issue? Would be great if this problem could be fixed.
Posted by Puybaret at Oct 29, 2020, 10:34:45 AM
From jkrief report, it looks like the problem is fixed in macOS Beta 11.0.1 20B5012d.
If you’re able to install this Beta version, can you confirm?
Posted by lfhring at Oct 30, 2020, 5:34:24 PM
Hi friends:
I want to confirm, the program is working well again in 11.0.1 Beta
Posted by mmrak at Nov 2, 2020, 8:57:56 PM
HI, I can also confirm that the program works again :-)
Posted by shabadoga at Nov 28, 2020, 7:21:53 PM
Hi all,
I'm trying to run version 6.4.2 on MacOS 11 Big Sur but i have no success. An alert says me to contact the developer to know if the app is compatible with this version of MacOS. Does anyone have the same problem?
Posted by Puybaret at Nov 28, 2020, 8:06:30 PM
Wouldn’t it be because Sweet Home 3D isn’t notarized yet (see bug #951)?
Posted by shabadoga at Dec 1, 2020, 10:12:16 PM
Thank you for reply. I opened the program through item in its contextual menu, but after that a new message saai me that i have to contact developer to be sure that the program can run in mac os 11
