Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Can't launch Sweet Home anymore |
| Print at Aug 1, 2026, 6:23:24 PM | |
| Posted by Paqueuc at Sep 10, 2020, 5:09:38 PM |
Can't launch Sweet Home anymoreHi, Windows 10, 6.3 64 bit version. Then upgraded to 6.4.2, 32 and 64 bit version I can't launch Sweet Home any more. It used to work fine, until I installed Java 8 for another tool. After installing Java 8, Sweet home wouldn't launch at all (no splash screen, nothing). I uninstalled it, reinstalled. Same thing. I found that I had to use the "Java web start". I did. I managed to launch it but immediately got the "Direct X fatal error". I updated the direct X drivers which were already up to date. I unistalled Sweet Home and reinstalled it. Not able to launch it anymore with both 1/ normal shortcut and 2/ Java web start. I thought this was coming from Java. I unistalled Java and sweet home. I reinstalled both. Same thing. I downgraded Java to version 6.45. Same thing. I even tried with the 32 bit Sweet Home version in 6.3 and 6.42. Same thing. I cleaned the registry "HKEY_CURRENT_USER\Software\JavaSoft\Prefs\com\eteks\sweethome3d". Same thing. I even changed the install directory. After each install / uninstall, I always restarted my computer. So is it the end of the game for me ? Seems like another registry key prevent me from a complete clean unistallation as nothing seems to fix the bug. And the more I try, the less I get results. It's been a few install / uninstall that I did see the splash screen for the last time (even with java web start). Anyone could have an idea ? Thanks, |
| Posted by FransW at Nov 9, 2020, 6:47:57 PM |
Re: Can't launch Sweet Home anymore Exactly same problem here. Since update to 6.4.2 I still see the splash screen. Even portable 6.4.2 doesnt work PLEASE |
| Posted by FransW at Nov 9, 2020, 6:50:07 PM |
Re: Can't launch Sweet Home anymore I even stole the jre from a other comuter on wich 6.4.2 works well, copied it in this version, I know its wrong, same, nothing works |
| Posted by Puybaret at Nov 10, 2020, 9:23:04 AM |
Re: Can't launch Sweet Home anymore Could you check if your issue is similar to the bug #967? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Paqueuc at Nov 10, 2020, 7:43:57 PM |
Re: Can't launch Sweet Home anymoreYes ! This is it. It works fine again ! Many great thanks. |
Current timezone is GMT Aug 1, 2026, 6:23:24 PM |
