Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: DWG to OBJ |
| Print at Sep 6, 2026, 5:13:23 AM | |
| Posted by KostasP at Aug 21, 2020, 6:48:24 AM |
DWG to OBJ Greetings, I had a friend create a file in Inventor then export it OBJ, I have attempted to imported the OBJ FILE to SweetHome with no luck. # WaveFront *.obj file (generated by Autodesk ATF) I am not sure how to attach the file for view on the thread. Any help would be appreciated. Regards Kostas |
| Posted by Puybaret at Aug 22, 2020, 4:28:00 PM |
Re: DWG to OBJ You should be able to attach a file now. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by KostasP at Aug 23, 2020, 5:03:16 AM |
Re: DWG to OBJ Thank you. We managed to make it work. I used the zip file that was sent later. Kind regards Kostas |
Current timezone is GMT Sep 6, 2026, 5:13:23 AM |
