Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Wände verbinden |
| Print at Sep 25, 2026, 4:35:24 PM | View all posts in this thread on one page |
| Posted by Doublebass at Aug 18, 2020, 10:18:07 PM |
Wände verbinden Hi all, when you make a room by walls, they often do not really "connect" properly. (They do if you make the room by building all they walls at once, clicking only one time after each part is done. But sometimes, this is not an option.) How it is: https://ibb.co/qRB1Kty How it should be: https://ibb.co/Y0xNzgx I made the 2nd pic by manually stretching the upper wall, making it long enough to start exactly at the position of the other wall. But this cannot be the appropriate solution? It can easily be messed up by unprecise drawing. There must be a way to "close" the wall automatically?? |
| Posted by Puybaret at Aug 19, 2020, 12:45:37 PM |
Re: Wände verbinden You should have double-clicked at the end of the last wall, or afterwards, you may select the walls to join and choose the menu item Plan > Join walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Doublebass at Aug 19, 2020, 11:31:05 PM |
Re: Wände verbinden ... or afterwards, you may select the walls to join and choose the menu item Plan > Join walls. That didn't work, repeatedly. Then I repeated trying it even more, then it worked... Thanks! |
| Posted by Mike53 at Aug 19, 2020, 11:45:53 PM |
Re: Wände verbinden https://www.youtube.com/watch?v=ezVttM5xd1A |
Current timezone is GMT Sep 25, 2026, 4:35:24 PM |
