Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Sweet Home 3D 6.4.2 |
| Print at Sep 23, 2026, 7:31:47 PM |
| Posted by Puybaret at Aug 8, 2020, 11:54:29 PM |
Sweet Home 3D 6.4.2 For your information, I released tonight the version 6.4.2 which fixes a nasty regression which detached joined walls, when split with Plan > Split wall menu item or recomputed with room modification pane. Please, update to this new version if you're using Sweet Home 3D 6.4. By the way, I'm happy to announce that the 28th language supported in Sweet Home 3D will be Thai. The translation was performed by กันย์ชัชชัย โพธิหล้า (Kanchatchai Potila) and its SH3L file is available in Translations page. Many thanks for his contribution. ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Xiste at Aug 9, 2020, 10:07:06 PM |
Re: Sweet Home 3D 6.4.2 Working on both Windows and OSX, I have made the following Yafaray observations: Windows seems to be a lot faster when rendering small and simple projects, while OSX seems to be much faster rendering more complex projects. Opening SH3D on Windows also takes significantly longer than opening SH3D on OSX. Any thoughts about this? |
| Posted by Puybaret at Aug 10, 2020, 9:57:04 AM |
Re: Sweet Home 3D 6.4.2 Thanks for your feedback ![]() The changes I programmed mainly targeted the regression on some joined walls. There was a very small change in the way plan icons are computed but I don't see how it could have made Sweet Home 3D run faster. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by hansmex at Aug 10, 2020, 11:12:04 AM |
Re: Sweet Home 3D 6.4.2 After installing version 6.4.2 under Windows 10, Immunet gave me a virus warning. See screenshot. Puybaret thinks it's a false positive, but maybe other users get the same message? Problem is that I can't run this version, so I had to re-install version 6.4. Unfortunately that gives the same problem. I'm investigating... UPDATE I uninstalled Immunet and installed Kaspersky. Problem solved!! H ![]() ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by bdfd at Aug 10, 2020, 3:40:22 PM |
Re: Sweet Home 3D 6.4.2 None problem for me. . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Xiste at Aug 10, 2020, 7:44:22 PM |
Re: Sweet Home 3D 6.4.2 Sorry. I have now tried some older versions on my Windows computer, and they behave just the same. This obviously has nothing to do with 6.4.2. |
| Posted by Mike53 at Aug 23, 2020, 11:35:23 AM |
Re: Sweet Home 3D 6.4.2 1 ... i am still getting walls disconnecting at corners, but only 2 of them, they are not split. there are a total of 18 walls 2 ... the method plan > connect walls works on all walls but right click > join walls does not on the same 2 corners ![]() this project has been saved numerous times. using W7 |
| Posted by hansmex at Aug 23, 2020, 12:30:50 PM |
Re: Sweet Home 3D 6.4.2 Did you check that the walls are drawn in the correct direction? H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Mike53 at Aug 23, 2020, 1:09:31 PM |
Re: Sweet Home 3D 6.4.2 yes m8. main point however is that i have to reconnect them every time i open the file |
| Posted by Puybaret at Aug 23, 2020, 2:37:24 PM |
Re: Sweet Home 3D 6.4.2 It would be nice if you could send me a simplified version of your file showing this bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 23, 2026, 7:31:47 PM |
