Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: Rebuild unsaved Furniture Library with FLE? |
| Print at Sep 6, 2026, 4:25:08 AM | |
| Posted by harbinger at Aug 6, 2020, 4:17:42 AM |
Rebuild unsaved Furniture Library with FLE? The Furniture Library Editor crashed (actually hung up) while I was importing a model from a zip archive. The library that I had created up to that point had not been saved. Now, I have found the location of the saved furniture and their previews in the work folder of SH3D. My question is, is it possible to recover the unsaved the library from this folder's contents? |
| Posted by Puybaret at Aug 7, 2020, 8:03:32 PM |
Re: Rebuild unsaved Furniture Library with FLE? As you probably observed, this folder contains files with temporary names. You could relaunch the editor then drag and drop all the .zip files you found in that folder onto the editor window. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by harbinger at Aug 7, 2020, 9:42:25 PM |
Re: Rebuild unsaved Furniture Library with FLE? Thank you! Worked perfectly! |
Current timezone is GMT Sep 6, 2026, 4:25:08 AM |
