Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Texture vs. Material |
| Print at Oct 19, 2026, 7:24:01 PM | View all posts in this thread on one page |
| Posted by mikewu99 at Jul 29, 2020, 4:43:30 AM |
Texture vs. Material I am a bit confused regarding applying texture to a piece of furniture (for arguments sake say a plain box). If I select the box, open modify furniture, then select texture then a texture is applied to every surface of the box, and the texture pattern is tiled across the surface. I do get strange effects on the side of the box (I am using a tile roof pattern). If I go into Materials->Modify and apply the texture to two sides of the box the texture is not tiled but is stretched to fit the side of the box. Resizing the box causes the texture to stretch along with the side. Am I doing something wrong? |
| Posted by Puybaret at Jul 29, 2020, 9:57:23 AM |
Re: Texture vs. Material You did nothing wrong. It's the way textures behave on the default box and you described it very well. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 19, 2026, 7:24:01 PM |
