Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Imported objects are transparent! |
| Print at Oct 6, 2026, 12:07:26 PM | |
| Posted by basil_battery at Jun 8, 2009, 12:15:00 PM |
Imported objects are transparent! Hello Every object I import from recommended site (www.archibaseplanet.com) looks transparent on 3D view. For example, I take this object http://www.archibaseplanet.com/download/16722.html and I see it like this http://s46.radikal.ru/i111/0906/8a/14e8d717c920.jpg Objects from this site are very useful for me. How can I make them visible? [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Jun 10, 2009, 1:19:00 AM |
Re: Imported objects are transparent! > How can I make them visible? The easiest way with Sweet Home 3D would be to: - import the model 3D file in an empty home - export it to OBJ format with "3D view > Export to OBJ format..." - edit the MTL file generated along with OBJ file with a text editor - change the transparency line that starts with "d xxx" to "d 1" - save MTL file - import the exported OBJ file ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by basil_battery at Jun 10, 2009, 2:00:00 PM |
Re: Imported objects are transparent! OK, It works, thank you |
Current timezone is GMT Oct 6, 2026, 12:07:26 PM |
