Print at Sep 29, 2026, 5:16:44 AM
Posted by JCPvanHooren at Jul 16, 2020, 4:00:04 PM
Rendering @ Q3/Q4 creating Black image/video
Somehow my brand new Dell XPS 15 with Intel UHD Graphics 630 seems unable to render either a photo or video at quality level 3 or 4 and only produces black images or video.
Since I don't believe SH3D is able to leverage my GeForce GTX 1650, I don't think that's very relevant.
Would highly appreciate a solution, as I am trying to simulate daylight animation throughout a day for my new house.
In video mode I can see a slight gradient change 'throughout' the day, but other than that, it only produces black images.
Everything works fine at quality levels 1 and 2, but this doesn't help me simulate sunlight.
Does anyone have any suggestions how to fix?
Thank you!
-Joost
Posted by hansmex at Jul 17, 2020, 6:26:50 PM
Re: Rendering @ Q3/Q4 creating Black image/video
Is it an indoor scene? In that case you have to add light sources, otherwise all will be black.
Posted by JCPvanHooren at Jul 18, 2020, 8:48:40 AM
I'm trying to simulate sunlight in my living room throughout a day. So yes, I'm taking a viewpoint in the room, but looking out through the (large) windows into the garden outside.
If I add light sources, it'd influence lighting in the room, while I'd like to simulate only sunlight.
I have tried adding a light in the middle of the room, just to test, but the rendered photo is still pitch black.
Maybe you can also help me understand the "Add ceiling lights" option. Does this just in- or exclude light sources you may have added?
Posted by hansmex at Jul 18, 2020, 11:56:42 AM
To simulate sunlight, you can make a video in which you change the time of day. When geo-location is set correctly, this will give you an impression of how the sun moves and penetrates the room(s). However, it will not correctly show the amount of light in the room, as SH3D makes room quite a bit darker than they in reality will be.
The ceiling light is a light source in the middle of the room that SH3D automatically adds to each room. You can switch it off in the photo/video rendering window.
Posted by Puybaret at Jul 18, 2020, 3:54:47 PM
See also this tip.
Posted by JCPvanHooren at Jul 19, 2020, 8:55:01 PM
I've read both the Sunlight simulation as well as the suggested tip, but I don't think my problem is related to light sources.
Even when I add a light in the middle of the room, the render remains black.
Any thoughts on what may be causing this?
Posted by Mike53 at Jul 19, 2020, 9:16:32 PM
If you are using the virtual visitor, make sure it is not positioned in or behind anything. SH3D has no light inside a room unless you add it.
Posted by harbinger at Jul 20, 2020, 1:54:12 AM
I had the same problem after an upgrade of sh3d many months ago. I forget what my fix was, but I believe it had to do with the rendering parameters. Try going from the simplest and work up from there.
Posted by gbrowne at Nov 14, 2022, 11:18:27 AM
Sorry to revive this thread, but I am getting the same problem now in 2022. This must have been fixed since, but I can't seem to make it work.
A simple scene renders fine with quality levels one and two, but the higher levels result in a black image. The lower levels render fine so its not a lack of light, or obscurement. Has anyone managed to get this to work since 2020 please ?
Posted by Puybaret at Nov 14, 2022, 3:11:35 PM
The two lower levels work completely an other way, so it's not a good starting point for comparison.
You should be sure that the point of view is not within a wall or an object, and that you added some lights. Generally, keeping the option Add ceiling lights option checked is a good start during a daylight hour.
