Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Photo-video rendering plug-in - crash |
| Print at Aug 15, 2026, 2:10:35 PM | View all posts in this thread on one page |
| Posted by bdfd at Jul 5, 2020, 9:39:41 AM |
Photo-video rendering plug-in - crashHi, With none answer, I decided to create this new thread. Pictures are better than words. The file : 65 MB compressed. Night texture in view 3D The parameters ![]() After launching, sh3d calculates during 10 sec and gives this picture. 1 sec after this picture, SH3D crashes down violently !!! Why ? NB : same file at noon = same crash same file with another texture for the sky = same crash same file with puybaret's yarafay plugin = same crash... same file with sunflow method is OK with PVR 1.9 same file with Standard rendering is OK... . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by hansmex at Jul 5, 2020, 10:51:12 AM |
Re: Photo-video rendering plug-in - crash Standard procedure for me is: - Delete half of your models and render. If it renders OK, you know that one of your models is at fault. - Repeat the process until you have the culprit. NB: I see a tree in your image. Trees can cause havoc during r endering. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Puybaret at Jul 5, 2020, 11:09:13 AM |
Re: Photo-video rendering plug-in - crash YafaRay is programmed in C++ not in Java, so in case of problem, it might make Sweet Home 3D crash much more easily than a Java library like SunFlow. Does it work with YafaRay rendering plug-in? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by bdfd at Jul 5, 2020, 11:56:00 AM |
Re: Photo-video rendering plug-in - crash ... Read better... or clean your pair of glasses Does it work with YafaRay rendering plug-in? . ---------------------------------------- Evil progresses when good people do nothing! --- SH3D 7.1 and nothing else - W11 64b in 4K |
| Posted by Puybaret at Jul 5, 2020, 4:19:26 PM |
Re: Photo-video rendering plug-in - crash Then try to make a SH3D as simple as possible that shows the problem and send it to me, because I couldn’t reproduce your issue the last time you mentioned it. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 15, 2026, 2:10:35 PM |
