Print at Aug 19, 2026, 7:36:02 AM
Posted by kpachodap at Jul 4, 2020, 3:46:48 PM
Modifying dimensions once after they have been added
I am using Sweet Home 3D 64 bit version for Windows. I am able to add dimensions to my floor plan, but after the dimension is added I do not see any option to select and modify or even delete the dimension. How can I accomplish this?
Posted by Puybaret at Jul 4, 2020, 6:52:59 PM
Re: Modifying dimensions once after they have been added
You can modify dimensions only with the mouse.
If you want to enter a precise value, type <Enter> when you initially draw it. See included help for more information.
Posted by hansmex at Jul 4, 2020, 6:53:27 PM
Select the dimension with the cursor, hit DEL to delete it.
Drag one of the sides to modify it.
It is not possible to modify it by typing a different value that autoscales the dimension.
Posted by kpachodap at Jul 5, 2020, 3:41:09 AM
Thanks Hansmex, I was able to do as you advised after unlocking my floor plan.
Posted by dorin at Jul 6, 2020, 1:25:29 PM
1. Install AdvancedEditingPlugin ;
2. Select dimension (or other thing) then click Resizes all selected items... button.
I use this frequently to insert more accurate dimensions.
Also pay attention to position buttons.
Posted by Gildaniel at Jul 8, 2020, 10:10:50 AM
Bravo!!!
