Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Drawing poly lines at angles - override 15 deg tolerance ? |
| Print at Aug 19, 2026, 9:33:49 AM | View all posts in this thread on one page |
| Posted by david_now at Jul 1, 2020, 4:45:49 PM |
Drawing poly lines at angles - override 15 deg tolerance ? Hi, I'm trying to poly lines. Horizontal & Vertical work fine, but when I try to draw other lines they allow options at 15,30,45,60,75 degrees. How do I reduce this 15 degree tolerance ? Thanks |
| Posted by Puybaret at Jul 1, 2020, 5:35:59 PM |
Re: Drawing poly lines at angles - override 15 deg tolerance ? Disable magnetism to get free angles ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by david_now at Jul 1, 2020, 6:02:12 PM |
Re: Drawing poly lines at angles - override 15 deg tolerance ? Thanks a lot. |
Current timezone is GMT Aug 19, 2026, 9:33:49 AM |
