Print at Aug 25, 2026, 5:31:51 AM
Posted by MorningZ at Jun 26, 2020, 11:36:27 PM
How to add curved sidewalk?
I've hit a dead end when it comes to doing something putting together my floorplan. I have a curved sidewalk in front and I have no idea how to represent it here in Sweet Home 3D
I found this post that is similar to my issue kind of, but I do not see what or where the "floor tool" is in the application (macOS version)
I've created the (temporary) walls for filling the floor, how do I do it? When I delete the walls, will that take the floor with it?
Is there another way?
Thanks in advance
Posted by bdfd at Jun 27, 2020, 7:31:13 AM
Re: How to add curved sidewalk?
You're on the right way.
Just select only the walls after create your pathway and delete them.
wink
Posted by hansmex at Jun 27, 2020, 11:19:48 AM
You're on the right track.
Enclose a space with walls, fill in with a "room" without ceiling. Then delete the walls you don't need. The room will stay.
Posted by Mike53 at Jun 27, 2020, 1:08:36 PM
The "room" tool is to the right of the wall tool
Select the tool, double click inside your walls, right click>modify room> uncheck ceiling as Hans says, you can modify the floor texture while your at it.
Posted by Mike53 at Jun 27, 2020, 1:12:45 PM
P.S. make sure all the walls are joined together, room tool will not function correctly if there is even the smallest gap.
VIDEO
Posted by MorningZ at Jun 28, 2020, 2:27:40 AM
Thanks for the help, done!!
