Print at Sep 21, 2026, 6:01:02 PM View all posts in this thread on one page
Posted by KitchM at Jun 19, 2020, 9:25:03 PM
Reordering Levels
Is it possible to reorder the levels once they are created?
Posted by Mike53 at Jun 19, 2020, 9:46:03 PM
Re: Reordering Levels
Yes......
Double click on the tab of the level you wish to change, a box will open enabling you to modify height, depth of floor and elevation, unfortunately, whilst the box shows all elevations you can only change settings for the one you initially choose. good luck
Posted by KitchM at Jun 19, 2020, 10:04:25 PM
Thanks. I looked into that, but the ability to reorder them seems to not be selectable. Any ideas?
Posted by UbuntuBirdy at Jun 19, 2020, 10:17:51 PM
You have to set the height of the levels to reorder them.
Pascal
Posted by KitchM at Jun 19, 2020, 10:18:06 PM
Okay, I think I've got it even if the order arrows do not work. What you do is change the elevation to -8'. That drops it below ground level, for instance.
Posted by KitchM at Jun 19, 2020, 10:18:57 PM
Wow, that was a cross-post. You are quite correct.
Posted by Mike53 at Jun 19, 2020, 10:21:50 PM
double click or right click on 1 of the tabs here .....
from the window that opens
you can modify the individual level and see where it moves to in relation to the other levels.
You can then open a window to the other levels
Posted by KitchM at Jun 19, 2020, 10:54:28 PM
Yep. Thanks, that helps.
Now if I can just view the basement area of a building in a view like you show of that house.
Posted by Mike53 at Jun 19, 2020, 11:22:19 PM
Can you show a view of what you are seeing?
Posted by KitchM at Jun 20, 2020, 12:29:28 AM
Thanks anyway, Pal. I got it figured out. It's starting to look halfway decent.
