Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: IRC Channel |
| Print at Aug 25, 2026, 7:17:17 AM | View all posts in this thread on one page |
| Posted by Jarod_Yang at Apr 17, 2009, 9:37:00 AM |
IRC Channel Hi all. I am beginner in Java. I found this project this week, and i am interested in it. I wanna ask that whether there is any IRC Channel for this project. So that we can communicate with each other easily. cheers Jarod [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Apr 17, 2009, 1:12:00 PM |
Re: IRC Channel Please, let's use this forum or email for the first steps of your discussion. What do you want to know? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Jarod_Yang at Apr 17, 2009, 2:01:00 PM |
Re: IRC Channel I have downloaded the source file In the "README" you only provided the compile way by Eclipse I got to try to compile by "ant" in command terminal. but i failed. Could you please provide me a way to compile the source code in terminal cheers Jarod |
| Posted by Jarod_Yang at Apr 17, 2009, 2:06:00 PM |
Re: IRC Channel ps. my system is ubuntu linux cheers |
| Posted by Puybaret at Apr 17, 2009, 7:55:00 PM |
Re: IRC Channel If you installed ant and java 5 or 6 correctly, the build.xml should work without any problem (all the files delivered in Sweet Home 3D project are built with Ant). What error do you get? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Jarod_Yang at Apr 18, 2009, 4:42:00 AM |
Re: IRC Channel u4457331@n115lt23:~/Desktop/SweetHome3D$ ant build Buildfile: build.xml build: [mkdir] Created dir: /home/u4457331/Desktop/SweetHome3D/build/classes [javac] Compiling 2 source files to /home/u4457331/Desktop/SweetHome3D/build/classes [javac] Compiling 151 source files to /home/u4457331/Desktop/SweetHome3D/build/classes [javac] Note: Some input files use or override a deprecated API. [javac] Note: Recompile with -Xlint:deprecation for details. [javac] Note: Some input files use unchecked or unsafe operations. [javac] Note: Recompile with -Xlint:unchecked for details. [copy] Copying 175 files to /home/u4457331/Desktop/SweetHome3D/build/classes [copy] Copied 15 empty directories to 1 empty directory under /home/u4457331/Desktop/SweetHome3D/build/classes [zip] Building zip: /home/u4457331/Desktop/SweetHome3D/build/SweetHome3D.jar [delete] Deleting directory /home/u4457331/Desktop/SweetHome3D/build/classes BUILD SUCCESSFUL It is OK until now. when i try to run the jar file there is the mistake u4457331@n115lt23:~/Desktop/SweetHome3D$ cd build u4457331@n115lt23:~/Desktop/SweetHome3D/build$ java -jar SweetHome3D.jar Invalid or corrupt jarfile SweetHome3D.jar I dont konw how to deal with it Is there any step wrong? my ant is the latest version cheers Jarod |
| Posted by Puybaret at Apr 18, 2009, 11:46:00 AM |
Re: IRC Channel You should have read *all* the comments at the beginning of the build.xml file http://sweethome3d.cvs.sourceforge.net/viewvc...sion=1.75&view=markup It describes the different available targets and I think the one you're looking for is the target named "jarExecutable", isn't it? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 25, 2026, 7:17:17 AM |
