Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Export 2D to dxf or dwg |
| Print at Sep 9, 2026, 10:16:31 PM | |
| Posted by rotbart at Apr 29, 2020, 5:13:04 PM |
Export 2D to dxf or dwg Hi, i´m new here but i didn´t found anything in the Forum. Is there a possibillity to export my fles as a dxf or dwg file??? Hope there will be some solution. Thx & best regards Andreas |
| Posted by dorin at Apr 29, 2020, 9:23:53 PM |
Re: Export 2D to dxf or dwg For this kind of task I use this way: 1. Plan->Export to SVG format... 2. Open the svg file with Inkscape 3. From Inkscape File->Save as... choose .dxf format. 4. Then You could open in LibreCAD or AutoCAD. You will don't have all the items but could be useful for start. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
| Posted by rotbart at Apr 30, 2020, 10:39:38 AM |
Re: Export 2D to dxf or dwg Hi, thanks for your help. But it doesn´t really work on my mac. So i tried the tool CAD Exchanger, which worked good for me... |
| Posted by greatway at Jun 25, 2026, 1:48:30 PM |
Re: Export 2D to dxf or dwg thanks for the tip ![]() |
| Posted by z56oo at Jun 26, 2026, 4:08:54 PM |
Re: Export 2D to dxf or dwg You can also try the plugin DXFexport |
Current timezone is GMT Sep 9, 2026, 10:16:31 PM |
