Print at Sep 26, 2026, 9:35:25 PM
Posted by manishlulla at Apr 28, 2020, 2:24:09 PM
Log Siding Texture & Color - Pluspuu
Hi All Power Users,
Hope you are well.
I am looking for a log siding / log home look as per the below links can you please help me to identify if a pre-existing color texture can achieve this look?
https://www.pluspuu.fi/en/mallisto/nauvo-roofdeck/
Thank you so very much in advance!
Best regards,
Posted by SeppoV12 at Apr 30, 2020, 11:59:23 PM
Re: Log Siding Texture & Color - Pluspuu
There is two sites where I have found that kind of textures: SketchUp Textures and Texturify.
Many other exists but look for seamless textures.
This texture might be pretty close you are looking for
When needed, I have made slight color/tone/size changes with programs like Paint.NET.
Good luck for search!
Posted by hansmex at May 1, 2020, 2:00:30 PM
Looks like black or charred wood to me. So maybe one of these ?
Posted by manishlulla at May 3, 2020, 3:00:40 PM
Thank you very much!
Posted by manishlulla at May 23, 2020, 4:39:18 PM
Hi Hansmex and SeppoV12,
I was able to download the images and apply as texture. However the image splits into squares. Is there a specific size or format I should be using to apply the image.
Thank you
Posted by hansmex at May 23, 2020, 5:25:28 PM
That's caused by a texture that isn't "seamless".
Search again adding "seamless|tileable" to your search terms.
Posted by manishlulla at May 23, 2020, 5:54:11 PM
Thank you!
Posted by manishlulla at May 23, 2020, 5:58:37 PM
Thank you again for the help!
When I import the texture and apply it the siding lines appear at uneven heights, not all siding lines are equidistant. How do I fix that?
