Print at Aug 1, 2026, 5:48:09 PM View all posts in this thread on one page
Posted by gar37bic at Apr 27, 2020, 2:18:43 AM
Trying to get HiDPI working - SH3d 6.3, Ubuntu 18.04
Folks,
I'm running an HP x360, Ubuntu 18.04. I'm trying to get SH3D running in HiDPI mode. I've tried the various suggestions I've seen, so far without any success - the program runs but it's all tiny. My most recent method was to edit the SweetHome3D shell script to run my local copy of java 13 (actually zulu-13). This runs fine AFAICT but is still not HiDPI.
The change I made was just to replace "$PROGRAM_DIR/jre8/bin/java" with /usr/bin/java, since my default java is now zulu-13.
I also tried adding -Dcom.eteks.sweethome3d.resolutionScale=2 to the script but that didn't make any difference. This is not my area of expertise, that was just shooting in the dark...
For completeness, here is the relevant part of my revised script:
exec /usr/bin/java -Xmx2g -classpath "$PROGRAM_DIR"/lib/SweetHome3D.jar:"$PROGRAM_DIR"/lib/Furniture.jar:"$PROGRAM_DIR"/lib/Textures.jar:"$PROGRAM_DIR"/lib/Examples.jar:"$PROGRAM_DIR"/lib/Help.jar:"$PROGRAM_DIR"/lib/batik-svgpathparser-1.7.jar:"$PROGRAM_DIR"/lib/jeksparser-calculator.jar:"$PROGRAM_DIR"/lib/iText-2.1.7.jar:"$PROGRAM_DIR"/lib/freehep-vectorgraphics-svg-2.1.1b.jar:"$PROGRAM_DIR"/lib/sunflow-0.07.3i.jar:"$PROGRAM_DIR"/lib/jmf.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dcore.jar:"$PROGRAM_DIR"/lib/java3d-1.6/j3dutils.jar:"$PROGRAM_DIR"/lib/java3d-1.6/vecmath.jar:"$PROGRAM_DIR"/lib/java3d-1.6/gluegen-rt.jar:"$PROGRAM_DIR"/lib/java3d-1.6/jogl-java3d.jar:"$PROGRAM_DIR"/jre8/lib/javaws.jar \
-Djava.library.path="$PROGRAM_DIR"/lib/java3d-1.6 \
-Djogamp.gluegen.UseTempJarCache=false \
-Dcom.eteks.sweethome3d.applicationId=SweetHome3D#Installer com.eteks.sweethome3d.SweetHome3D \
-Dcom.eteks.sweethome3d.resolutionScale=2 \
-open "$1"
Posted by Puybaret at Apr 27, 2020, 11:32:58 AM
Re: Trying to get HiDPI working - SH3d 6.3, Ubuntu 18.04
Could you try with "$PROGRAM_DIR/jre8/bin/java"?
Posted by gar37bic at Apr 29, 2020, 10:56:58 AM
I did that first, and the app came up but it was not in hidpi mode, very tiny. That's why I tried modifying the script as shown above, after I tried all the things I found online. I'm open to suggestion :)
Posted by gar37bic at Apr 30, 2020, 12:59:49 AM
Following up, I've tried the following - it seems to work exactly the same in all cases.
- 6.3 download, stock
- 6.3 modified as shown above
- Ubuntu distribution version
- 'Portable' all architecture version
I also tried to get the Java Web Start version working with suggested parameter mod (" -Dcom.eteks.sweethome3d.resolutionScale=2") I don't recall if I got that working, but if I did it was just the same.
Posted by gar37bic at Apr 30, 2020, 1:03:56 AM
I'd just like to add that I used SH3d a number of years ago on a different project with great success. I appreciate the effort all y'all have put into this, and I'm confident that we can make it work! :D
Posted by jpc31 at May 25, 2020, 6:34:29 PM
Just solved it (not very clean). I'm running Arch and I just hacked the /usr/bin/sweethome3d script.
I've just added the -Dcom.eteks.sweethome3d.resolutionScale=2 in the options of the launch command and it worked like a charm.
I guess I'll have to redo the same after the next update ;-)) So I will document it right now.
Hope this helps
Jean-Pierre
Posted by Puybaret at May 26, 2020, 3:47:06 PM
Thanks for your feedback. Setting the com.eteks.sweethome3d.resolutionScale property is not wrong wink
