Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Using SH3D Portable's Java Files to Run the TLE & FLE |
| Print at Aug 21, 2026, 7:43:17 PM | View all posts in this thread on one page |
| Posted by T3NZ3N at Apr 25, 2020, 7:34:48 PM |
Using SH3D Portable's Java Files to Run the TLE & FLE In the documentation, I think it's mentioned that we can just run the TLE & FLE JARs from the Portable SH3D's own Java Files in it's own jre Directory. I can't figure out how to set this up so I can run the TLE or FLE jar files from the files in the jre folder. I'm running win10pro The only executables with the java program Icon I found in the jre/windows/x64/jre8/bin were the javaw.exe I tried simply dragging & dropping the jar to that and every other exe file in the bin, but nothing happened. I currently have jportable in the Portable SH3D directory along with the Portable Launcher, but I'd like to try and see if there is a way to launch them directly without those, by using only the files in jre/windows/x64/jre8/bin Additionally, I'm curious if the Portable SH3D Executable is just a Natively packaged Java File. Thanks for any help |
| Posted by Puybaret at Apr 25, 2020, 7:40:37 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE The command to run a JAR file is: path/to/java.exe -jar executable.jar(you may also use javaw.exe) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by T3NZ3N at Apr 25, 2020, 7:42:21 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE How can I add that to the launch parameters of the jar? and will it be dynamic, if the drive letter changes? |
| Posted by T3NZ3N at Apr 25, 2020, 7:43:55 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE And when you say "I may use javaw.exe", what does that mean? How do I use it to make it do something. |
| Posted by Puybaret at Apr 25, 2020, 7:55:39 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE I'm not sure you can change the launch parameters if java is not installed. If you want to reuse the command you should rather store it in a .BAT file. And when you say "I may use javaw.exe", what does that mean? Simply replace java.exe by javaw.exe in the command I wrote.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by T3NZ3N at Apr 25, 2020, 8:03:43 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE would the batch file just look like this? "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/java.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar" that didn't work for me |
| Posted by T3NZ3N at Apr 25, 2020, 8:05:15 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE Except I used javaw.exe, as there is no java.exe in that folder |
| Posted by T3NZ3N at Apr 25, 2020, 8:07:03 PM |
Re: Using SH3D Portable's Java Files to Run the TLE & FLE Sorry, you need an edit button. The entire Bat file looked like this: Run "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/jre/windows/x64/jre8/bin/javaw.exe" -jar "E:/Portable Programs/3D Programs/SweetHome3D-6.3-portable/FurnitureLibraryEditor-1.25.jar" that didn't work for me |
Current timezone is GMT Aug 21, 2026, 7:43:17 PM |
