Print at Sep 29, 2026, 1:42:42 PM
Posted by 9seidean7sidh3 at Apr 24, 2020, 8:48:17 PM
Application Crashes Mac and have to hard reboot
Hi, the last four days Sweethome 3D have caused me to have to (hard) reboot my MAC which completely crashes... cursor moves but no access to dock or any menu items....before this I had no problems.... today I searched to see if there was an update, and there was, so I installed thinking it just needed an update... nope still crashing the whole system...
It occurs usually when I am trying to move an object but no particular object.... I don't build walls or anything I simply layout the room and add furniture for rearranging...
The only changes I have made is updating Safari and some sort of security patch from Apple a couple of weeks ago but no other changes to the system... Thank you
Posted by Puybaret at Apr 25, 2020, 1:46:13 AM
Re: Application Crashes Mac and have to hard reboot
What system do you use?
Posted by 9seidean7sidh3 at Apr 25, 2020, 2:42:37 AM
Os x 10.14.6
Intel Iris Graphics 6100 1536 MB graphics
Intel Core i7
Processor Speed: 3.1 GHz
Number of Processors: 1
Total Number of Cores: 2
L2 Cache (per Core): 256 KB
L3 Cache: 4 MB
Memory: 8 GB
Posted by 9seidean7sidh3 at Apr 26, 2020, 6:58:57 PM
Any Ideas?
Posted by 9seidean7sidh3 at Apr 27, 2020, 2:23:39 AM
I tried the Java Web Start version and same thing as with the download version...
Posted by Puybaret at Apr 27, 2020, 11:35:30 AM
Please try the version of Sweet Home 3D which runs with Apple Java 6 that you'll have to install too.
Posted by 9seidean7sidh3 at Apr 27, 2020, 9:53:26 PM
No joy.... although it took probably 2 to 3 hours to crash instead of 20 minutes... it did so eventually.... and other tricks too try?
Posted by Puybaret at Apr 27, 2020, 10:01:53 PM
I fear that Apple introduced a regression in their recent security update, so either you wait they fix it (but are they aware of the problem?) or you upgrade to Mojave if it’s possible (I would avoid Catalina unless you’re 100% sure all your apps are 64 bit).
Posted by 9seidean7sidh3 at Apr 28, 2020, 1:42:27 AM
Ok... I am already on Mojave so I wait to see if they provide another update... thank you...
Posted by Puybaret at Apr 30, 2020, 11:33:45 AM
Sorry, I mixed your issue with the one of another user. Mojave is the system I use everyday at the moment and I didn't experience any problem on my side. There must have been an other change in the past weeks...
Posted by kelleychambers at May 17, 2020, 12:52:34 AM
confused   Re: Application Crashes Mac and have to hard reboot
Same here... and a Mojave user as well... except my lockup happens when I'm in Virtual Visitor viewport. This is the latest issue; I've had more problem with SH3D than I can shake a stick at and it's driving me nuts!
