Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Print Each Room on a separate page? |
| Print at Aug 21, 2026, 5:47:50 AM | |
| Posted by jadube at Feb 6, 2009, 3:11:00 AM |
Print Each Room on a separate page? My home has 3 'Rooms'. SH3D scales the home (all rooms) to fit on one page which makes the 2d view too small for my purpose. I'd like the 2d view of each room on a separate page (Letter size PDF printing). How can I do this? [Note: this thread was started on sourceforge.net forums] |
| Posted by Puybaret at Feb 6, 2009, 10:16:00 AM |
Re: Print Each Room on a separate page? Create a new temporary home, copy/paste the room you want to print in that new document, and print it. For better results, choose the same scale for each print with Print setup dialog. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Johan_Martijn_Flaton at Feb 6, 2009, 3:42:00 PM |
Re: Questions / Suggestions (Walls, Layers) I simply adore the program! Layers would be indeed a great help - making it possible to stack the different floors of a home? But what I really like would be to make walls temporarily invisible, just like you can do with any other object, making it possible to travel in 3D in a fast dolly-like move. Is there some sneaky way to get that done? I tried to set the wall thickness to zero but no cigar ;-) Kind regards, velijn |
| Posted by pencilart at Feb 6, 2009, 5:03:00 PM |
Re: Questions / Suggestions (Walls, Layers) Yes, that can be done. You do this in the Virtual Visit mode (Right click in the 3D pane, click on "Modify" and then look near the bottom of that window, it says, "Walls Transparency", just move the slider from dark to light. :D |
Current timezone is GMT Aug 21, 2026, 5:47:50 AM |
