Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: .png image on wall or object with transparancy... |
| Print at Oct 6, 2026, 7:45:02 AM | View all posts in this thread on one page |
| Posted by justthewayur at Apr 1, 2020, 6:01:48 PM |
.png image on wall or object with transparancy... Can I make either a vertical wall or object, apply a .png image of a tree that has transparancy around the tree, then see that in a 3d view and have the transparent areas of the .png image be invisible, the same as a .png behaves as a 2d image ? Thank you. Justina |
| Posted by Puybaret at Apr 2, 2020, 8:43:46 PM |
Re: .png image on wall or object with transparancy... You may do that on the side of a thin box found in Miscellaneous category, but not on walls. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by justthewayur at Apr 3, 2020, 7:13:37 PM |
Re: .png image on wall or object with transparancy... Thank you. May I ask for a tip please on how to plan the correct size of the image and dpi if I wish a real life size of 5 feet tall by 4 feet wide, and maintain the aspect ratio of the image on the box without stretching. Cheers. |
| Posted by Puybaret at Apr 3, 2020, 7:36:51 PM |
Re: .png image on wall or object with transparancy... It's explained in this tip. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by justthewayur at Apr 8, 2020, 6:34:47 PM |
Re: .png image on wall or object with transparancy... Thank you. [Solved] |
Current timezone is GMT Oct 6, 2026, 7:45:02 AM |
