Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: sweet home 3d does not start correctly in the manjaro operating system (arch-linux) |
| Print at Aug 21, 2026, 8:06:18 PM | View all posts in this thread on one page |
| Posted by jhonnca at Mar 21, 2020, 2:57:41 PM |
sweet home 3d does not start correctly in the manjaro operating system (arch-linux) apparently there are conflicts with the java package. terminal exit when launching sweet home 3d application. WARNING: An illegal reflective access operation has occurred WARNING: Illegal reflective access by javax.media.j3d.JoglPipeline (file:/usr /lib/sweethome3d/java3d-1.6/j3dcore.jar) to method sun.awt.AppContext.getAppC ontext() WARNING: Please consider reporting this to the maintainers of javax.media.j3d .JoglPipeline WARNING: Use --illegal-access=warn to enable warnings of further illegal refl ective access operations WARNING: All illegal access operations will be denied in a future release Inconsistency detected by ld.so: dl-lookup.c: 111: check_match: Assertion `ve rsion->filename == NULL || ! _dl_name_match_p (version->filename, map)' faile d! link to the topic within the manjaro forum. https://forum.manjaro.org/t/sweet-home-3d-does-not-start-correctly/130724/3 |
| Posted by Puybaret at Mar 22, 2020, 9:22:03 AM |
Re: sweet home 3d does not start correctly in the manjaro operating system (arch-linux) These are just warnings ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by jhonnca at Mar 22, 2020, 12:19:53 PM |
Re: sweet home 3d does not start correctly in the manjaro operating system (arch-linux) so how can i offer useful data to solve this? believed that it was just a java bug in the manjaro repositories (arch-linux) and that updating or replacing the repository would suffice. |
| Posted by jhonnca at Mar 22, 2020, 8:23:10 PM |
Re: sweet home 3d does not start correctly in the manjaro operating system (arch-linux) the problem was resolved for the Manjaro-Kde plasma system. To test it, you must run sweet home 3d through the terminal: command line to execute: SWEETHOME3D_JAVA3D = 1.5 sweethome3d link to the open topic in manjaro where you can find more information. https://forum.manjaro.org/t/solved-sweet-home...-start-correctly/130724/7 |
Current timezone is GMT Aug 21, 2026, 8:06:18 PM |
