Sweet Home 3D Forum » List all forums » » Forum: Sweet Home 3D bar » » » Thread: html5 error 0 |
| Print at Aug 5, 2026, 3:32:42 PM | View all posts in this thread on one page |
| Posted by sunkgrowsupply at Mar 19, 2020, 2:00:15 PM |
html5 error 0 I keep getting error 5 while requesting ( *.zip file ). I tried searching error 0 in the forum with nothing coming up. anyone have the quick fix for this? |
| Posted by Puybaret at Mar 19, 2020, 9:53:20 PM |
Re: html5 error 0 I guess you should allow your browser to read local files or host the exported files on a web server. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Alex210 at Apr 23, 2020, 11:14:19 PM |
Re: html5 error 0 Check this thread hope it might help you, http://www.sweethome3d.com/support/forum/viewthread_thread,6708 |
| Posted by davequ at Mar 8, 2021, 12:42:03 AM |
Re: html5 error 0 Having an issue trying to get the default html to work. Opening it in Chrome (latest version Version 88.0.4324.190 on Windows 10) get Error 0 when requesting default.sh3d. I have checked the settings and File System access is on, as is Allow apps to access... Also tried C:\PROGRA~2\Google\Chrome\Application>chrome.exe --allow-file-access-from-file but seems to make no difference. I get a tab with a View Home button, and ...HTML5 Viewer at the bottom. but on clicking the button get the error. |
| Posted by Puybaret at Mar 11, 2021, 10:24:54 AM |
Re: html5 error 0 Apparently, Chrome wants to make it harder and harder to use it for developers ![]() From this page, you should now run Chrome with the following options: --disable-web-security --user-data-dir="[some directory here]"for example: --disable-web-security --user-data-dir=ChromeTemp---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by vinaayaksingh at Jan 24, 2023, 6:19:36 PM |
Re: html5 error 0 Browser blocks local file. Assuming you have dev env setup You can install very simple dev server & then access the html from browser via server. Here are the steps: 1. Installing the Node.js http-server. Its simple. Open cmd prompt and type: npm install http-server -g Then go to the folder where your html file is there. open cmd prompt in that folder. and type command: http-server . -p 8000 Now you can open http://127.0.0.1:8000/ and then from there open your html file. Above is just one method. There are many such server available. |
Current timezone is GMT Aug 5, 2026, 3:32:42 PM |
