Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: windows 3D builder |
| Print at Sep 21, 2026, 11:44:43 PM | View all posts in this thread on one page |
| Posted by philippes4 at Mar 13, 2020, 4:49:45 PM |
windows 3D builder Impossible to import a 3d furniture created with 3D BUILDER (windows 10) en .OBJ, it worked well before, but now the import only works with a 3d .DAE model that removes colors and textures .... Thanks for your help |
| Posted by Puybaret at Mar 13, 2020, 6:45:41 PM |
Re: windows 3D builder Difficult to help you without an error OBJ file. Could you share one or send it one to me? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by philippes4 at Mar 14, 2020, 9:35:22 AM |
Re: windows 3D builder Thanks for your help. I send you a 3d model wich it makes an import error in sweethome |
| Posted by philippes4 at Mar 14, 2020, 9:43:14 AM |
Re: windows 3D builder it seems that the problem arises as soon as you add colors to the model in 3D builder. A simple shape without color does not pose a problem and is imported without error into 3D sweethome. |
| Posted by Puybaret at Mar 14, 2020, 11:25:56 AM |
Re: windows 3D builder Thanks for your file. The OBJ file can't be read because it doesn't respect the OBJ format specifications. As it's a text format, you can check by yourself: lines starting by "v" are supposed to describe a vertex with the 3 values of its coordinates (and a possible 4th value used as a weight). In the file you sent, "v" lines are followed by 6 values, making it wrong. It will work if you remove the trailing 3 numbers of "v" lines. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by philippes4 at Mar 14, 2020, 1:26:55 PM |
Re: windows 3D builder Ah... how can i check my 3d model with a text format ? |
| Posted by Puybaret at Mar 14, 2020, 3:18:14 PM |
Re: windows 3D builder Just open the OBJ file with any text editor. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by philippes4 at Mar 14, 2020, 4:58:52 PM |
Re: windows 3D builder in this line for example : "v -60.698318 69.639313 141.979401 0 0 0" how many values and wich numbers can i remove ? how did you found the wrong lines in my 3d model ? thanks |
| Posted by Puybaret at Mar 14, 2020, 8:48:05 PM |
Re: windows 3D builder I think you should rather use another tool or a different export format... ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by philippes4 at Mar 15, 2020, 3:29:57 PM |
Re: windows 3D builder it woks when you only use "texture" for the 3d model (doesn't work if you change a color) Thanks for all |
Current timezone is GMT Sep 21, 2026, 11:44:43 PM |
