Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: projection of room walls on a 2D plan » » » » Post: projection of room walls on a 2D plan |
Print at Sep 20, 2026, 5:07:57 PM |
| Posted by deverne at Feb 21, 2011, 11:21:26 PM |
projection of room walls on a 2D plan Hello, I'm a newbie to Sweet Home 3D and a new Java developer. I work on house plan with Sweet Home 3D which is a very nice application. I need to generate 2D plan of the wall from the 3D model. I read at the SH3D API which is very well documented and try for one week to generate a SVG file containing the projection of the wall. Today, the result is not as good as expected. I encounter the following issues: - Unable to locate the door and windows on the wall and draw them at the right place. - Unable to detect precisely which room is behind a given wall. What is the way to do that? - Look's like sometimes the room boundary points are in clockwise order, and sometime in anticlockwise. So I suspect that some of my rooms are drawn in reverse order... - Difficult to remove the very little walls generating when a door is encountered in a wall. Like in the following draw: The code is available for every one. Where should I sent it? Just ask it ? The obtained plans are very useful to prepare the future quotations... Thanks for your help, Deverne |
Current timezone is GMT Sep 20, 2026, 5:07:57 PM |
