Sweet Home 3D Forum » List all forums » » Forum: Forum in other languages » » » Thread: Wie kriegt man Schrägdachfensgter hin? » » » » Post: Re: Wie kriegt man Schrägdachfensgter hin? |
Print at Sep 20, 2026, 8:39:34 AM |
| Posted by hansmex at Feb 17, 2011, 2:40:54 PM |
Re: Wie kriegt man Schrägdachfensgter hin? Tom, Read that manual again... almost all the info is in it. Let me explain in shorthand: 1 - draw two walls at a 90 degree angle in the form of an A 2 - insert a window in one of the walls 3 - CopyAsNewFurniture 4 - Export as OBJ 5 - Import and rotate Voila, a roof with a window. To make it perfect you have to prepare your window: a - insert the desired window in an empty design b - Export as OBJ c - Import and rotate (so that it will fit correctly in the roof, once the roof is rotated to its final orientation) d - use this window in step 2 Note: the Velux windows in the Sketchup Warehouse often are rotated 45 degrees (or so). That may make it difficult to insert them in a wall/roof. Use any ordinary window and give it the correct Velux-size. Hans PS: If you want your V-server question answered, ask it again in the English forum. I'm not sure Emmanuel will answer it when in German. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 20, 2026, 8:39:34 AM |
