Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Round walls aren't round? » » » » Post: Round walls aren't round? |
Print at Sep 6, 2026, 9:01:05 AM |
| Posted by hansmex at Jan 25, 2011, 2:13:16 PM |
Round walls aren't round? Emmanuel, I always wanted to make a spiral staircase like this one: So, I devised a way to make it in SH3D using round walls. This is how I did it: - draw a round wall with an angle of 180 degrees - correct XY coordinates to exact round numbers - make it sloping from 300 to 0.1 cms - then use CopyAsNewFurniture, Paste, Export to OBJ format - Import furniture twice, rotating the second model so that it's upside-down. - stack the two objects, and voila. It's only then that I discovered that (1) round walls aren't perfectly round or (2) that I must have done something wrong. The image below shows a clear band on the left where the top and lower half don't line up. ![]() Do you have a solution? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 9:01:05 AM |
