Print at Sep 14, 2026, 12:21:41 AM
Posted by macfrog at Jan 23, 2011, 11:32:40 PM
not enough sunlight?
emmanuel, hans,
now after i nearly finished the outer hull of my home, including roof, i came to the conclusion (i mentioned light issues before...) the incoming sunlight is much to dark in most cases. maybe its not "correctly" reflected from walls or whatsoever, but i think a room with lots of glass should look flooded with light at noon.
is the radiosity support somebody brought up a while ago still on the table and would that solve my "problem"?
btw i had to finish the entire house because you said its not possible/wanted to look from top into a room and block sunrays coming in from ceiling without enabling ceilings (and therefore ceiling lights) - as i remember correctly. so now i can actually see proper light conditions.
greets
macfrog
