Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How do you group and ungroup objects? » » » » Post: Re: How do you group and ungroup objects? |
Print at Sep 6, 2026, 12:09:23 PM |
| Posted by hansmex at Jan 22, 2011, 5:13:23 PM |
Re: How do you group and ungroup objects? Mark, There is a solution to do this using the AdvancedEdit plug-in. In the manual there is a paragraph dedicated to a Trick: How to move the entire design. This would of course work on part of your design as well. There is another solution, that's much easier, but has some drawbacks. Using the plug-in CopyAsNewFurniture you can select, then copy and paste a part of your design. You can then very easily shuffle your room-blocks in any way that pleases you. The drawback is that you cannot edit your blocks. So, my solution would be to use trick #2 to play, then use trick #1 to make the definitive plan. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Sep 6, 2026, 12:09:23 PM |
