Print at Sep 21, 2026, 4:07:38 PM
Posted by Puybaret at Jan 12, 2011, 5:40:22 PM
Re: Can't load IA 32bit .dll on a AMD-64bit platform
I should probably deliver a 64 bits version for Windows too.
You probably use a 64 bits JRE, but could you try if 64 bits IE accepts to run applets with a 32 bits JRE? As I think the Online applet is run in a separate process, I don't know if it would work.
