Print at Aug 24, 2026, 12:27:32 AM
Posted by hansmex at Jan 7, 2011, 2:44:04 AM
Re: how do I add texture to bottom half of walls?
Jared,
There are several ways to do this.
1 - Using the plug-in CopyAsNewFurniture
- Draw the walls of your room
- Copy the four walls to a different location for each of the colours or textures you want to use
- Give the first set of walls the height of the lowest colour, then apply that colour or texture
- Repeat the process for the second (and third, etc) part of your design on the second (and third) set of walls
- Select the second part and copy it using Tools --> Copy as new Furniture
- Paste the copy into your design, change its elevation and place it exactly on top of your first set of walls
- Repeat for more colours or textures
NOTE: This way left and right side of the wall may have different aspects
2 - Using insertable boxes
- Take a standard box and export it using 3D view --> Export to OBJ format
- Import it again making sure you check the checkbox Door/Window
- Apply the colour or texture you desire to the box, and give it the desired height and width, as well as the correct elevation
- Insert the box into your wall
- Repeat for more colours/textures
NOTE: This way both sides of the wall look the same
3 - Using an imported texture
- Use a graphics program like The Gimp to make the desired texture for the full height of your wall
- Import the texture and apply it to your wall
NOTE: This way both sides of the wall may have different aspects
4 - Read this tutorial for another way
Good luck!
