Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: import obj with texture » » » » Post: Re: import obj with texture |
Print at Sep 6, 2026, 11:50:41 AM |
| Posted by Puybaret at Dec 28, 2010, 4:46:50 PM |
Re: import obj with texture mekkelek, You can edit the MTL file if you want to, but you should know that Sweet Home 3D doesn't support all the options available in the MTL format. For example, map_Kd lines that specify information about texture, supports only a file name for the image of the texture and no scale or shift options. If the exported MTL file shows such options, you should modify the UV coordinates of your model in Maya in such a way the texture image don't need any scale. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 11:50:41 AM |
