Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: bug in transparent rendering? » » » » Post: Re: bug in transparent rendering? |
Print at Oct 22, 2026, 5:23:23 AM |
| Posted by hansmex at Dec 17, 2010, 4:47:23 PM |
Re: bug in transparent rendering? Emmanuel, After another round of playing around with the hidden (or should I say "forbidden"?) fruits of transparency, I came across some more unexpected behaviour. The idea was to explore the possibilities to make a roof, in this case the sloping side of a "standard" roof. I drew a triangle with walls at 60 degr angles, with two walls sloping at a 45 degr angle. I then inserted a room, made the floor invisible, and deleted the walls. CopyAsNewFurniture copied just the roof, which was then ex- and imported as an OBJ. So far pretty standard. The results are show below. Picture 1 - Aerial view Picture 2 - Virtual visitor Clicking the name of the pictures gives access to a larger screenshot. It may be worth noting that: - neither in Aerial View, nor in Virtual Visitor are the triangles visible in the 2D or in the 3D preview - if I apply colours to the triangles, they behave more normal, and are visible from one side only (as a roof is "supposed" to behave). The link below downloads the sh3d file. Hans Transparent roofs ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 22, 2026, 5:23:23 AM |
