Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: memory problem » » » » Post: memory problem |
Print at Aug 17, 2026, 12:46:54 AM |
| Posted by hansmex at Nov 23, 2010, 11:23:45 AM |
memory problem Emmanuel, Today I had a strange problem, most probably stemming from memory management. What happened is, that after importing a new DAE model, and inserting it in my design, every model I tried to insert, was that same last model I imported. In this case, I imported the horse, than tried to insert a sphere or a cylinder, but while dragging that model, it was the horse that became attached to the cursor. When I save the file, close and restart SH3D, the problem is solved. However, the window does not open in its previous size (full screen). I attach the file that has this problem, although I am not sure you can reproduce it. This same problem happened for the first time a few days ago, certainly no more than a week, and it happened again right now while testing v3b21. I don't remember what I was doing when it first happened. Today, I had done quite a bit of rendering for the three test pictures I showed in another post, so it's hard to say whether it's the DAE model, or the repeated rendering that clogged the memory. Hans http://www.mediafire.com/?3ls2ztdc4whkw26 ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 17, 2026, 12:46:54 AM |
